Re: When you disc...........????
Posted by Nat 2 on May 22, 2007 at 06:24:23 from (64.80.110.50):
In Reply to: Re: When you disc...........???? posted by Patrick Martin on May 22, 2007 at 03:24:43:
Drag disc harrow: No wheels, attached to the tractor with a clevis and pin. There is no way to lift the discs off the ground for transport or turning. For transport, the disc gangs are straightened out and the whole rig rolls along on its discs.
Transport disc harrow: Has wheels and a hydraulic cylinder to lift the discs off the ground.
Mounted disc harrow: Is mounted directly to the tractor via 3pt, Fast Hitch, or other mounting system and is lifted by the tractor.
With a 100, you probably have a mounted disc.
