Farmall Tractors Discussion Board
Re: Re: Re: Farmall M backfire
Posted by RickB. on May 08, 1999 at 07:22:03:
In Reply to: Re: Re: Farmall M backfire posted by RKS on May 08, 1999 at 04:14:33:
The average M could idle for 6 years and not reach 150 degrees. It could be anything, of course, but I'd bet the mechanical advance under the breaker plate is inoperative, coupled with a lean-running carb. You should hear a bad valve. A compression check is certainly in order.
Post a Followup
: Re: Re: Re: Re: Farmall M backfire
