Re: M hydraulics?
Posted by georgeky on May 22, 2007 at 07:55:31 from (64.12.117.8):
In Reply to: M hydraulics? posted by M.Rad. on May 22, 2007 at 04:48:56:
You can place a vent plug in one end of cylinder to relieve pressure and it will work as a one way cylinder. Just remove hose from the end not needed and add the vent plug. I have lots of two way cylinders rigged this way. You can also put on the double set of couplers on the tractor and simply hook the hose up to one without a line coming from tractor and let it breath this way. I have all of mine coming off the right side fitting of tractor.
