Re: Bolts, Grades
Posted by Steven@AZ on May 23, 2007 at 08:40:01 from (216.67.213.217):
In Reply to: Bolts, Grades posted by SuperA-Tx on May 23, 2007 at 07:02:18:
If there is no marking I would have to assume that they are a grade 2 "soft" bolt that is only good for the lightest fastening chores.
