Re: Bolts, Grades
Posted by Nat 2 on May 23, 2007 at 09:26:12 from (64.80.110.50):
In Reply to: Bolts, Grades posted by SuperA-Tx on May 23, 2007 at 07:02:18:
No marks means Grade 2, period.
If you're buying bolts from Grade 5 or 8 bins that have no marks on them, you are being screwed.
