Re: 460 clutch adjustment
Posted by K.B.-826 on May 23, 2007 at 16:38:15 from (24.180.143.209):
In Reply to: 460 clutch adjustment posted by CNKS on May 23, 2007 at 14:41:12:
1/8" to 1/16" sounds about right on bearing to lever clearance. Did this problem occur right after the new clutch was installed? If so, could be many things. Was the flywheel surfaced, and did it get machined to the correct specs? Did the new disk slide freely on the splines? Any chance the disk was damaged during reassembly? Could it be something like the pedal linkage flexing?
