Re: Farmall A Over Heating!!
Posted by El Toro on May 24, 2007 at 04:10:07 from (64.12.117.8):
In Reply to: Farmall A Over Heating!! posted by Jason1(Pa.) on May 23, 2007 at 18:31:58:
I would bet the problem is as Gene suggested. When I did an A it was loaded with dirt and crud around those sleeves. I had the sleeves out, so I steam cleaned the block. That's a good area for a leak too is around those seals on the sleeves.
If the sleeves are ever pulled that block area needs to be cleaned very well. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
