Farmall A Over Heating!!
Posted by Jason1(Pa.) on May 23, 2007 at 18:31:58 from (4.155.123.238):
Im working on someones "A".. It had a blown head gasket and I replaced it. I didn't see any cracks any where and everything look real well. Got it back together and it runs nice however it over heats pretty fast. I thought there may have been a air pocket so i drained it a few times and put the antifreeze back in. still have the problem..Any Idea on why this may be? And Yes the rad was cleaned out very well. Thanks!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
