Re: Well I am stuck on the stuck engine
Posted by glennster on May 24, 2007 at 10:59:56 from (76.224.16.173):
In Reply to: Well I am stuck on the stuck engine posted by neblinc on May 24, 2007 at 06:01:39:
lookin at your crankcase photos, i'm thinking after you get the main caps off, you may be able to kind of lift and roll the crank a little to expose the #2 and 3 rod caps, block the crank up with some wood andpull the caps, should be able to lift the crank out then. cant remember but i think you need to drop the oil pump to get the cam out. you may be able to knock or press the pistons out the bottom, pretty rusty to come out the top. dont bend the rods, they are pricey. coming along real good tho. did you find any mice or wasps in her????
