Butch
Posted by BF8690 on May 24, 2007 at 13:03:54 from (138.163.0.44):
In Reply to: Re: CNKS Can you help with axle seal replacement o posted by Butch WI on May 24, 2007 at 10:47:23:
there isn't a cap on the end of the axel housing? I'm not familiar with 460s. If you have to remove the axel you can do it through the PTO. I found it easiest to do this way by removing the retaining bolts on the bull gears. Then using a bottle jack, push the axel out.
