Re: CNKS Can you help with axle seal replacement o
Posted by Butch WI on May 24, 2007 at 10:47:23 from (69.179.89.118):
In Reply to: Re: CNKS Can you help with axle seal replacement o posted by BF8690 on May 24, 2007 at 09:32:17:
Mine has the splined outside of the axle. the wheel hub slides onto those splines and is then held in place by a bolt and retaining washer. I need to know how to get the axle out. I am familiar with the one you are describing...the wheel hub is clamp mounted onto the axle.
