Re: M clutch blew
Posted by BF8690 on May 24, 2007 at 13:06:48 from (138.163.0.44):
In Reply to: Re: M clutch blew posted by Bob M on May 24, 2007 at 13:00:19:
You don't have to split the tractor on an M to do that unless it has the 12" clutch. On my '44M I changed the Pressure plate, Friction plate and throwout bearing without splitting the tractor. Everything comes out through the hole where the belly pump mounts. I've been told that the 12" clutch can not be done this way.
