Re: Need help identifying IH model
Posted by Milton on May 25, 2007 at 08:05:17 from (216.135.39.196):
In Reply to: Need help identifying IH model posted by Parish Mills on May 25, 2007 at 06:27:00:
Parish Mills, --- 25 / May / 2007 ---
Your International T 2400DA is a Indstrail
tractor with a Diesel / most likely a D179 /
3 cylinders (motor was made at the IH Plant in
German).
The I 2400A was made from 1970 to 1974.
S# 223006OU002539 should read as ---------------
S# 223006(O)0U002539 was most likely made in
1970. This I"m checking out to be sure.
EMail me at "farmall28@yahoo.com" if you need
more info.
Milton
