Farmall Tractors Discussion Board
Re: Re: Re: 1256 hyd. problem
Posted by SDman on May 08, 1999 at 22:19:06:
In Reply to: Re: Re: 1256 hyd. problem posted by karl fischer on May 08, 1999 at 20:08:16:
From the info you are telling me, I still would suspect the MCV pump. 15 years of normal use is about the life expectancy of these pump, especially if the Hy-Tran has not been changed like it should be. Worn pumps show up like you describe, when it's cold out, it takes forever to get power steering, TA, brakes. Also, if your red TA light works, does it flicker on/off when you idle the tractor down after a good day's work when the tranny gets good and warm? That's another tell-tale sign. By the way, the O-ring Miles is talking about is between the front & rear halves of the trans. to get to it. You have to split the tractor to change that o-ring, not an easy task.
Post a Followup
: Re: Re: Re: Re: 1256 hyd. problem
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
