Re: 966 Charging System.
Posted by Weldon K on May 25, 2007 at 19:03:00 from (71.28.67.247):
In Reply to: 966 Charging System. posted by GordoSD on May 25, 2007 at 17:41:58:
Replace the resistance unit. Porcelain thing with wire terminals on each end , found just above or below voltage regulator. Remove sheet metal panel beside park lock operating lever to gain access to voltage regulator. These tractors will not charge the batteries if the resistance unit is bad. Been there , done that. Could be voltage regulator also.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
