806 hydraulic trouble
Posted by chadd on May 25, 2007 at 19:51:09 from (65.147.160.2):
Hi guys,
I was wondering if anyone has had to change the metal hydraulic lines that run behind the tractor frame and then go under the radiator and to the steering motor. Do I have to remove the radiator, or can I get away with just removing the frame from the side and then pull the hydraulic line through underneath the radiator? I really don't want to pull the radiator, as the connections will probably be very rusty, and I need to get it up and running so we can finish with planting.
Thanks,
Chadd
