Re: Farmall A Over Heating!!
Posted by dave guest on May 25, 2007 at 20:42:11 from (4.229.123.234):
In Reply to: Farmall A Over Heating!! posted by Jason1(Pa.) on May 23, 2007 at 18:31:58:
How hot is too hot? I have A using for 15 years. Purty darn hot runner. Can't keep your hand on radiator. Was told to use water not antifreeze in summer and keep belt tight. No water pump. Added electric fan as supplement. Maybe little cooler. Late timing can make cars run hot, I guess tractor, too. Never boils. But I have cub and is hardly ever warm at all.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
