Farmall 560 oil bath air filter maintenance
Posted by Rylee on May 25, 2007 at 20:49:50 from (75.100.184.59):
I need to know how to clean an oil bath air filter, other than just dumping the oil and changing the oil.
Are there any special things to do to the filter elements themselves?
And is 30 wieght motoroil good enough in the oil cup?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
