Re: 966 Charging System.
Posted by El Toro on May 26, 2007 at 08:45:24 from (152.163.100.197):
In Reply to: Re: 966 Charging System. posted by GordoSD on May 26, 2007 at 05:48:53:
If the charging voltage is ok you need to check the specific gravity of the elecrolyte in each battery cell and compare them, they should be around 1.250 or better. If one is around 1.100 that battery probably needs to replaced. Hal
