Re: SM carb adjust
Posted by jpl on May 26, 2007 at 15:16:00 from (66.209.132.126):
In Reply to: SM carb adjust posted by Soldner on May 26, 2007 at 15:06:25:
you have adj on bottom, turn it out 5 turns, gas it up and check for black smoke, you may have to turn it in a little, if that dont do it, you need to take it apart and clean the high speed jet tube, it has small holes in it and may be plugged. also check your screen where gas line hooks up.
