Re: Super A 12v conversion
Posted by HENRY E NC on May 26, 2007 at 19:58:22 from (216.119.7.174):
In Reply to: Super A 12v conversion posted by 51Farmall on May 26, 2007 at 17:26:29:
Why are you changing to an alternator? Your Generator will charge the battery just as well with less problems. Generators and starter do npot know the difference between 6 and 12 volt.Just use a 12 volt battery, resistor on the coil and changer light bublbs. I have a 51 M like that and it works fine. My 41 A is mag driven but uses a generator and starter with a 12 volt battery, and lights. Works great.
