Re: Monarch Snowplow Pump on M
Posted by Clarkbug on May 27, 2007 at 05:42:53 from (209.23.8.79):
In Reply to: Re: Monarch Snowplow Pump on M posted by Janicholson in LA on May 26, 2007 at 12:19:36:
Thanks for the reply!
Ill have to try and see what I can get for information off of the pump. It looks like its an older unit, so I dont know if the company is still around or of there is a model listing for them somewhere. Then I also would need to find one of the actual units that mounts on the steering shaft and see what kind of flow those would need...
I definitely dont want to make something unsafe, but was more just curious about using this pump for a different purpose than it was put on for.
Thanks for the input!
