Re: farmall 400 gas// transmission
Posted by D Slater on May 27, 2007 at 09:46:40 from (72.65.141.110):
In Reply to: farmall 400 gas// transmission posted by vac54 on May 27, 2007 at 09:13:04:
Housings and transmission gears are the same,but unless you change to the row crop ring and pinion the tractor will be faster. The axles and axle housings would need switched along with top cover and pedals,some linkage parts and so on. If you refer to rear drain on transmission something probably got under bull gear. If T/A housing and T/A is good on the W-400 the transmission main shaft with pinion gear can be removed from the rear after removing differential which you would have to do anyway for ring gear change. Just listed your options,this is not a recommendation on what is best to do.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
