Re: Super A 12v conversion
Posted by SuperA-Tx on May 27, 2007 at 10:11:29 from (4.90.52.236):
In Reply to: Super A 12v conversion posted by 51Farmall on May 26, 2007 at 17:26:29:
Heres some mounting plates.
http://www.alternatorparts.com/Alternator_brackets_1.htm
For the top support I ordered part #60714DA and part #49288DA from OEM Tractor Parts. By useing the two parts together it curves over the alt and with the two slots together you can adjust the tightness.
Use this diagram for the three wire conversion. It says for an H/M but it is the same as on a SA.
http://albums.photo.epson.com/j/ViewPhoto?u=4001561&a=30065733&p=60243702
Go with the three wire because its hard to get a one wire setup to excite without a small pulley and reving the motor up every time. If you use the delco 10SI it should bolt to your old base with a longer bolt.
