Re: CNKS here's the plug PIC
Posted by CNKS on May 27, 2007 at 18:45:20 from (204.249.178.32):
In Reply to: CNKS here's the plug PIC posted by Butch WI on May 27, 2007 at 18:28:45:
OK, never paid any attention to it, and I have had those pieces completely disassembled and painted. That would come out pretty easy when hit from the inside. If you have power steering, on the right side of that unit, when viewed from the rear when installed is a dome held on by 4 bolts, Inside is a piston. The inside of the dome on mine was pitted by long term water in the fluid. I had a sleeve installed. You might check that, it is not hard to take apart. Leaks are prevented mainly by an o ring, but mine also uses a gasket that will probably have to be replaced. Since you have it off, you took the hyd lines loose from that dome, provided it has power steering.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
