Re: All you Woods belly mower gurus
Posted by DelMN on May 28, 2007 at 03:54:40 from (67.72.98.91):
In Reply to: All you Woods belly mower gurus posted by Hugh MacKay on May 28, 2007 at 03:34:58:
In my opinion, the best way to check deck height is to put it on a level cement slab and measure the left and right sides and also front to back. Left to right should be the same, front slightly lower that back. Things that could cause it to tilt are tire pressure on the tractor, chain adjustment different. Also it could differences in the height that you mow. Check the above at the level that you mow. Bent spindle or bad bearing could also be a problem. Good luck!
