Re: All you Woods belly mower gurus
Posted by Bob Kerr on May 28, 2007 at 13:59:34 from (152.163.100.197):
In Reply to: All you Woods belly mower gurus posted by Hugh MacKay on May 28, 2007 at 03:34:58:
I have an L59 on a B6100 kubota and it is getting pretty wore out on the front casters. One caster was replaced 15 years ago and the other is still original so the soild tire wear is a factor on mine. Both casters need replacing now. The spacer washers on the casters are the height adjustment when mower is down, so definatly check those. also someone mentioned a bent spindle or bad bearing, spindle bent would cause swirls but a bad bearing on an outer spindle could cause blade to pull up on the outside. if it was that sloppy though I would think you could hear it growling.Good luck with it.
