Looking for some reasurance or opinion on my H
Posted by Jim-In-NY on May 29, 2007 at 18:34:24 from (70.110.104.23):
I had some transmission issues that i decided to fix this spring. I replaced the third and fourth gear on the countershaft and the fourth and fith on the top shaft (both used) along with a new driveshaft. After i put it back together it had a whining sound. I thought that it might have been the driveshaft big gear rubbing against the countershaft gear. I shimmed it out and that didnt solve the problem.
i was thinking maybe it was a bearing but if it didnt have this problem before it shouldnt know right?
Could it be the new driveshaft not meshing with thecountershaft well. It should break in right?
I checked it for play and it does have a little not really side to side like a bad bearing but a little slop in it.
so what do you think?
all opinions welcome
thanks for your help
James
