Re: brake/clutch shaft and pedal bushings
Posted by CNKS on May 29, 2007 at 19:39:12 from (204.249.178.32):
In Reply to: Re: brake/clutch shaft and pedal bushings posted by nspec on May 29, 2007 at 19:09:34:
Replace them, any place that specializes in seals and bearings can cross the IH number to Chicago Rawhide or National, the two major seal suppliers. Or get them from Case-IH, price is usually higher for the exact same seal. Easy to get out without the shaft installed.
