Re: Farmall Super C fluids
Posted by Ed342 on May 30, 2007 at 21:06:03 from (216.234.99.204):
In Reply to: Farmall Super C fluids posted by Ed 342 on May 30, 2007 at 19:56:51:
Paul - Thanks for the reply. I have a small plug, about 5/8, on the right rear though, on the very end of the main axle gear box and level with the centerline of the axles, close to the pto housing but not on it. Would that be it?
If this is a drain plug and not a level plug (like the two motor oilpan units)how do I monitor the correct oil level in the trans/axel/pto unit?
Do you have a thought about using synthetic blend oil in the engine?
Final question, any idea of what a reasonable labor charge would be to replace a broken axle on a C?
Thanks, Ed.
You're right about liking the Super C. It's an absolutely beautiful machine. And that 2-pt. fast hitch is a wonder. I've used an H for a number of hours and it's just not the same.
Thanks again, Ed
