Re: Gear lube capacity of 140 and Farmall Cub
Posted by Hugh MacKay on May 31, 2007 at 03:24:51 from (209.226.247.109):
In Reply to: Re: Gear lube capacity of 140 and Farmall Cub posted by Tab on May 30, 2007 at 20:31:22:
Tab: The 140 fill to level plug is on the left side, directly below front tip of left fender. Allmost directly behind left brake pull rod.
I always fill my tractors to the plug, install the plug and add a quart. I find with a bit extra oil in there, I get smoother shifting, gears slow down faster after tractor has been idling and you depress the clutch.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
