Re: Gear lube capacity of 140 and Farmall Cub
Posted by Tab on May 31, 2007 at 05:36:49 from (4.152.234.20):
In Reply to: Re: Gear lube capacity of 140 and Farmall Cub posted by Hugh MacKay on May 31, 2007 at 03:24:51:
Thanks for the info. That sounds good. Would you know how many hp my 140 has? I used to operate one for a local tobacco farmer(now deceased), and always wanted one for gardening. Then I found this one with several pieces of equipment, and no rust. Even the battery box(with top) is solid. It is one of the older ones, with the horizontal bars on the grill. Got a 2-bottom plow, disc, tillis tool, and corn planter(one row). Wish I had the fertilizer attachment. Thanks again for all the info.......Tab
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
