Re: Positive Ground?
Posted by Peter Hatlestad on May 31, 2007 at 16:23:37 from (216.249.198.149):
In Reply to: Positive Ground? posted by A. Bohemian on May 31, 2007 at 14:53:21:
It's a positive ground and I installed the battery correctly. I does shows a 10 amp discharge when the lights are on and the engine is off. As I would expect. It started doing this about a day before I replaced the battery.
When I arch the "A" generator pol to the "battery" terminal pole On the Voltage Regulator ... to reset the polarity it sparks... but it doesn't reset the polarity as I would hope.
Pete
