firing order on md?
Posted by jonnnny2006 on May 31, 2007 at 18:52:47 from (67.142.130.34):
what is the firing order on a md? is it 1-3-4-2-?
i know the mag spins backwards so ill take that into consideration. plus i have not moved the motor from the spot of when i took off the mag. so i should just be able to point the rotor one plug at a time and eventually it should line up right? i had to retime the little gears in the mag and it works perfect now. to i have to retime the mag to the engine all over or will i be able to put it on and move it one plug at a time till it is right? but i need to know the correct firing order
