Re: All you Woods belly mower gurus
Posted by Hugh MacKay on June 01, 2007 at 03:00:26 from (216.208.58.136):
In Reply to: Re: All you Woods belly mower gurus posted by dionne on May 31, 2007 at 12:33:56:
dionne: I lift my mower using only the right rockshaft. I have one chain down from right rockshaft, which splits to a Y about 8" from mower deck. My mower deck has notched loops about 14" apart, to which I hook each chain from the Y.
To keep mower from floping when traveling with it raised, I have 2x4 blocks U clamped to each mower push bar. These raise to touch stops I have bolted to front of final drives.
I solved my uneven cutting height with 3/4" thrust washers on spindle shaft of caster wheels. I went to a store that specializes in nuts, bolts, etc. he sold me these thrust washers in 3 different thickness. With these washers I was able get it same height both sides on concrete floor. Following that it worked fine out in the grass.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
