Re: im going to bed befor its light out!!!
Posted by glennster on June 01, 2007 at 07:34:30 from (76.224.16.173):
In Reply to: im going to bed befor its light out!!! posted by jonnnny2006 on June 01, 2007 at 02:33:28:
if the mag is not spinning and you have a live pump, i kinda suspect the cam drive gear broke. take the valve cover off and turn the engine over, if the rocker arms are moving, the gear is still good. if not, you gotta pull the front end off the motor and change the gear. if the rocker arms are moving, you probably need to pull the mag and see if something sheared off there, then go to the live pump and check the shaft and gears there.
