Re: #@**I !! My M is locked up
Posted by John M on June 01, 2007 at 14:30:04 from (204.116.130.100):
In Reply to: #@**I !! My M is locked up posted by StevenL on June 01, 2007 at 11:05:43:
Just for the heck of it, pull the starter and make sure that its not binding. Turning the fan by hand doesnt mean anything, as the belt can be tight enogh to keep it from spinning by hand. It was spinning after you changed the oil right, so chances are you blew most of the water out then. Id pull the starter, aint but two bolts and a nut. What do you have to lose?
