Re: 560 -- Stuck in 2 gears or other problem...hel
Posted by Clefus on June 01, 2007 at 18:43:51 from (75.88.177.58):
In Reply to: 560 -- Stuck in 2 gears or other problem...help... posted by Clefus on May 31, 2007 at 18:28:49:
I pulled the shifter and slid them to line up...The tip of the shifter has some braze on it( pretty worn)....may need done again if I have this happen...
Tractor vet -- I turned the TA to clutch lingage in 2 turns seems to help....tractor coasts like you said also...TA is a little harder to get in the catch when pulling the lever but I can play with that later....
Thanks to all the guys for the help....
