Re: #@**I !! My M is locked up
Posted by ChadS on June 02, 2007 at 07:25:03 from (4.224.78.158):
In Reply to: Re: #@**I !! My M is locked up posted by JT on June 01, 2007 at 12:24:57:
Make an adapter to hook up an air hose, that has 18mm threads that screws into the spark plug hole. Remove the rocker arms make sure all the valves are shut, pour in some ATF, and then hook up the air hose. An adjustable regualtor onthe air hose works best, or up to a 150 psi. Maybe try to hook the hose up to all 4 cyls with some ATF,,, it will help push the fluid past the pistons, while you have the air hooked up, hit the starter button,,, if its not stuck hard, it will pop right loose, but, you got to get the cyls cleaned out asap, so think of pulling the head in the near future, or, keep flushing the cyls with some sort of cleaner,,, paint thinner mineral sprits, diesil fuel, and keep rotating it with the starter once in a while to blow the cyl out, or tear it down as soon as you get it unstuck. Hope this helps. I used an old spark plug, with the porcilin (spellin) broke out and welded a fitting that works with the air hose, welded the two together. Better yet, pull the manifold off, if it looks really bad in the ports,,, dont try to start it,, all that rust will go right into the motor, and it wont run for long. ChadS
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
