Re: Update on Cub
Posted by El Toro on June 04, 2007 at 03:55:16 from (152.163.100.197):
In Reply to: Update on Cub posted by 1941 farmall a boy on June 03, 2007 at 20:49:48:
You need to bring No1 piston to TDC on the compression stroke. You need to feel the compression and you need to crank it slow until the notch on the damper pulley is aligned with the
pointer. Turn the rotor to the No1 plug tower where your plug wire connects to the cap. No1 is near the radiator. Then install the mag. Hal
