Re: bearing or bushing in 450 steering
Posted by SDE on June 04, 2007 at 15:16:02 from (69.179.19.223):
In Reply to: bearing or bushing in 450 steering posted by Alan in VA on June 04, 2007 at 14:29:05:
If you have that component removed from the tractor, you could take it a machine shop and ask them if they could make a sleeve to fit inside that worn out housing. They would need to bore the housing out in order to be able to get the sleeve centered properly.
I assume yours is the same as my 400, and mine are worn also.
SDE
