Re: IHC W450-D Question for the pros **(URGENT)**
Posted by the tractor vet on June 04, 2007 at 21:28:33 from (75.19.120.54):
In Reply to: IHC W450-D Question for the pros **(URGENT)** posted by Brian Jensen on June 04, 2007 at 20:40:57:
Now before my eye lid slam shut here , what you are sayen is that ya can not get it started on the gas side?? If this is the case and nothing has happened to the engine as to a gear taken a dump up ft. or that ya had your pinkies into it . First make sure that when ya make the switch from diesel side to the gas side that the switch over switch in the ft intake manifold is maken the switch and ya have juice going to the dist. if it has a dist. and not a mag . now if it has a mag then ya have to make sure that that switch is not grounding out the mag. Now are you 100% sure that the switch over is alos opening up the needel valve in the carb to allow gas to enter the carb . There are some things to check if ya got it out of time and someone else doe not give ya a hand let me know AFTER I get done inspecting the inside of my eye lids and this wiil take some time.
