Re: Overflow 560
Posted by Leon Torkelson on June 05, 2007 at 05:07:00 from (70.100.94.80):
In Reply to: Overflow 560 posted by bent1 on June 05, 2007 at 03:38:08:
Check your radiator fins to see if they are cloged. I took the grill off my 560D to clean it out last year. the other posts are right, a radiator will puke if over filled. a cooling system will reach an operating level after running it. Watch your temp gage and check coolant level, if it isn`t dropping below the top of the tubes when looking down the filler neck you should be good.
