Re: Overflow 560
Posted by the tractor vet on June 05, 2007 at 07:31:27 from (75.19.120.54):
In Reply to: Overflow 560 posted by bent1 on June 05, 2007 at 03:38:08:
Well first off is it a gasser or a diesel ??? , As others have said check the easy stuff first . Mowen hay can plug the fins on the rad. pull the grill and with compressed air blow out from back to ft. from top to bottom .Mkae sure that your fan belt is tight . as for the thermostat ????? don't know for sure here as i am not there to check . If it is a diesel ya may have some seirous problems . like a cracked head or block . this can be checked with out pulling the engine down and works on both gas and diesel . Here is who ya do that , first drain the cooling system down till ya can remove the thermostat and housing remove the fan belts so the water pump does not turn make sure that the engine is cold with the coolant level at the top of the mounting face of the thermostat start the engine and rev the engine if she pushes coolant out the littel darling have internal injurys if no coolant pushes out then it is either the water pump the thermostat or rad.. It's like going to school do the easy stuff first them move on to 2nd. grade and so on.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
