Transmission trouble on 1256
Posted by John Abbott on June 06, 2007 at 20:10:28 from (64.12.117.8):
My boss has a 1969 international 1256. I was bushogging with it a month or so ago and when i used the brake to turn it popped and quit pulling. I checked the hydrolic fluid and ended up putting 5 gallons in it. We got it to the shop and put a new clutch in it and it still wont move. If you change gears without depressing the clutch you can hear the gear grind just a little bit but then it goes into gear. The power steering and brakes still work. The light on the dash does not work but when we put a manual guage in the spot where the sending unit was we didnt get any thing. The smallest mesurment on the guage is 50 psi and it didnt move. Any ideas on what the problem could be?
