Re: what size speedi-sleeve for super c crank pull
Posted by Mark Doud on June 07, 2007 at 05:44:34 from (207.68.116.74):
In Reply to: Re: what size speedi-sleeve for super c crank pull posted by El Toro on June 06, 2007 at 16:42:20:
I knew I needed to replace the seal and the sleeve, but I already had a new seal from a rebuild kit I bought.
I wasn't aware there would be a difference between the seal in the kit and the seal that comes with the speedi-sleeve. Or are you just saying that I need to replace the seal when I install a new sleeve?
Thanks
Mark D.
