Re: what size speedi-sleeve for super c crank pull
Posted by El Toro on June 07, 2007 at 10:15:09 from (64.12.117.8):
In Reply to: Re: what size speedi-sleeve for super c crank pull posted by Mark Doud on June 07, 2007 at 05:44:34:
I called the local IH dealer and they're not sure
if the seal comes with the speedi sleeve. Its now over $18.00. Hal
