Re: oil out the axle seals?
Posted by MN Scott on June 07, 2007 at 06:39:43 from (206.9.216.45):
In Reply to: oil out the axle seals? posted by jonnnny2006 on June 06, 2007 at 20:55:00:
There is an oil level check plug on the left side of the tractor transmission housing in front of the clutch pedal. It should be a square headed plug. Park it on the level and pull the plug. If oil runs out let it run until it quits then you should be good to go. If it does'nt run out add oil till it does.
