Re: 424 differential lock
Posted by Rex in Australia on June 08, 2007 at 14:58:22 from (59.100.124.1):
In Reply to: 424 differential lock posted by Dave in Southern Illinois on June 08, 2007 at 12:51:28:
Dave, I just went through a similar situation with my 434. Was doing the brakes and thought i would replace the oil seals. The pinion shaft carrier will not come out due to the large bull gear inside protruding up through a gap in the carrier. Have a look at the parts manual on line at Caseih.com and you will see what I mean.
I ended up leaving mine as to get it off I believe you will have to remove the hydraulics off the top and get through to remove the bull gears. I couldn't do mine due to not being able to lift off the hydraulics.
I think i am right, maybe someone else can chip in.
God Bless,
Rex
