Re: 424 differential lock
Posted by Dave in Southern Illinois on June 08, 2007 at 15:07:44 from (216.138.60.195):
In Reply to: Re: 424 differential lock posted by Rex in Australia on June 08, 2007 at 14:58:22:
I have everything off and out of the rear case except the differential itself. The bearing cages pull out after the bull gears are out of the case. The left side was easy but I cannot get the right side out. I don't understand how the retainer that holds the diferential lock shaft inside the pinion shaft is removed so the bearing cage will slide all of the way out. Thanks for the reply. I will work on it some more tonight.
